Hello,
I'm using these settings in LAV Splitter:
Audio: svk,slo,cze
Subtitles: svk:svk|f slo:slo|f cze:cze|f eng:svk|!f eng:slo|!f eng:cze|!f eng:eng|!f *:svk|!f *:cze|!f
It works good with most files, but with one TV-series the subtitles are enabled, even if they are not forced. I have to manually disable subtitles.
Video info:
- video: mkv, 1080p, x264, English [eng]
- audio: Czech [cze] ac3 (active)
- audio: English [eng] dts (inactive)
- subtitles: Czech [cze] (subrip) (active)
- subtitles: no subtitles (inactive)
AFAIK cze:cze|f means, that with Czech audio only Czech forced subtitles should be enabled, but here it doesn't work, non-forced subtitles are enabled. Is it possible that it's a conflict with PotPlayer subtitles options? If so, should I remove it?
I use these options in PotPLayer, which should not be used with mkv files:
Preferred languages: forced&sk forced&slovak forced&cze forced&czech
Thanks in advance.
LAV Splitter 0.70.2.74-git, PotPlayer 1.7.4353 64-bit, Windows 10 Home 64-bit.
Results 1 to 14 of 14
Try:
svk:svk|f slo:slo|f cze:cze|f cze:off eng:svk|!f eng:slo|!f eng:cze|!f eng:eng|!f *:svk|!f *:cze|!f -
I have another problem, using these options:
svk:svk|f svk:off slo:slo|f slo:off cze:cze|f cze:off eng:svk|!f eng:slo|!f eng:cze|!f eng:eng|!f *:svk|!f *:cze|!f
cze:cze|f should load czech forced subtitles for czech audio, but for one file "EN forced [eng]" are loaded instead, why? "CZ forced [cze]" subtitles are available in the list. -
Container is mkv? "CZ forced [cze]" means:
Name of the track: "CZ forced"
Language: Czech
No forced track flag
But for cze:cze|f to be used you need: "whatever [cze] [forced]". The "[forced]" indicates the track has the forced track flag. You can edit the flag with Mkvtoolnix' Header Editor. Alternatively LAV can also pick up on track names with the "@" operator:
svk:svk|f slo:slo|f cze:cze|f cze:cze@forced cze:off eng:svk|!f eng:slo|!f eng:cze|!f eng:eng|!f *:svk|!f *:cze|!f
That will also select tracks with Czech language flag and with the string "forced" anywhere in the track name. -
I'm sorry, it's mkv, Matroska.
I tried also to change "cze" to "cz", since the name is "cz", still the same, English forced subtitles are loaded at start.
cz:cz|f cz:cz@forced
BTW, in PP and LAV tray icon menu the names for subtitles look like this:
S: CZ forced [cze] (subrip) [default,forced]
S: EN Forced [eng] (subrip)
In PP file info:
Audio:
Title : CZ DD 5.1 @ 640 Kbps BluRay
Language : Czech
Service kind : Complete Main
Default : Yes
Forced : Yes
Text #1
Title : CZ forced
Language : Czech
Default : Yes
Forced : Yes
Text #2
Title : CZ
Language : Czech
Default : No
Forced : No
Text #3
Language : English
Default : No
Forced : No
Text #4
Language : English
Default : No
Forced : No
Text #5
Title : EN Forced
Language : English
Default : No
Forced : No
Text #6
Title : CZ PGS
Language : Czech
Default : No
Forced : No
Text #7
Title : SK PGS
Language : Slovak
Default : No
Forced : NoLast edited by Dreamer; 27th Oct 2017 at 12:37.
Hi,
dont know if it helps but in PP there is in preference subtitles Language/sync/others english subtitles as prefered. But I suppose you are using czech language in settings. Try delete eng etc. here. So left only cze cz cs czech Česky as prefered.
Its Potplayer thing, isnt ?
Bernix -
Bernix, thanks for the reply. PP settings are not used if LAV splitter is used, but I had those options in PP changed already, to CZ...
I have another problem. Using these options in LAV:
svk:svk|f svk:off slo:slo|f slo:off cze:cze|f cze:cze@forced cze:off eng:svk|!f eng:slo|!f eng:cze|!f eng:eng|!f *:svk|!f *:cze|!f
In the movie MKV, the only subtitle available is:
CZ Forced [cze] (subrip) [default]
...but "No subtitles" is used though, why? In most other cases it works good.
I tried to add "cz" instead of "cze", but it doesn't work. -
OK, I found a reason for the problem, PotPlayer changed options and I used old settings from backup, problem "solved" with a workaround, it was/is a PotPlayer issue.
Always post complete MediaInfo. The selection is about audio:subtitle pairs. Without complete info it's not possible to tell. Also include info about audio selection.
I'm using these options for PotPlayer, LAV splitter:
Currently, many movies has 2 forced subtitles, pgs and subrip, by default, pgs are loaded.Code:svk:svk|f svk:off slo:slo|f slo:off cze:cze|f cze:cze@forced cze:cze@Forced cze:cze@FORCED cze:off eng:svk|!f eng:slo|!f eng:cze|!f eng:eng|!f *:svk|!f *:cze|!f
How to change my options (above), to prefer non-pgs or subrip forced cz subtitles, but only if available, if not, load any cz forced subtitles, even pgs.
Thanks in advance.
Lav splitter affects vfw codec?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2013, 11:53 -
Embed subtitles with lav filters?
By dude112 in forum Video ConversionReplies: 3Last Post: 22nd Sep 2013, 08:33 -
LAV splitter ignores preferred audio track
By xepyonx in forum Software PlayingReplies: 0Last Post: 30th May 2013, 07:04 -
Issue with 32-bit portable LAV Filters
By djb247365 in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2013, 16:00 -
Issue with Portable Version of LAV Filters
By djb247365 in forum Software PlayingReplies: 2Last Post: 10th Feb 2013, 15:44
